13 years ago
More control over dashboard / widget display - stacking, side by side, variable width
Here is a minor cosmetic request.
When setting up a widget dashboard I may have 4 or 10 widgets I want to display, each of varying width.
I know that I can position these as I wish, but I would like more control.
I may want certain widgets displayed at the top, others in the middle, etc.
These widgets may be of different width. Example NOC vs Alerts.
Example: Display NOC widgets side by side ( as many as I specify ) , then display the alerts underneath in full width.
Here is some pseudo code for a table layout , similar logic could be used for div\'s
Widget 1Widget 2Widget 3 Widget 4 Widget 5Widget 6Thanks,
Kevin
Widget 1Widget 2Widget 3 Widget 4 Widget 5Widget 6Widget 7
