Joe_Tran's avatar
Joe_Tran
Icon for Advisor rankAdvisor
7 years ago
LM Cloud - AWS RDS - system-level prop for Endpoint Address
Is it possible to populate monitored AWS RDS instances with the connection endpoint address as a system-level property?
I'm not sure how we would be able to query the RDS instance directly if we don't have that when we have a Collector assigned to fetch custom metrics.
1 Reply
  • Sarah_Terry's avatar
    Sarah_Terry
    @Joe Tran Yes -it shouldn't be too hard for us to add in the connection endpoint as a system prop for RDS instances. We'll try to get that in the next few releases.
