Joe_Williams's avatar
Joe_Williams
8 years ago
Issues With Creating A Datasource
I took a working groovy script datasource and am now trying to adjust it to some needs we have. This data will end up giving us alert totals for each month so we can build reports. Any ideas?
Here is what I have so far.
import javax.crypto.Mac;
import javax.crypto.spec.SecretKeySpec;
import org.apache.commons.codec.binary.Hex;
import groovy.json.JsonSlurper;
//define credentials and url
def accessId = hostProps.get('lmaccess.id');
def accessKey = hostProps.get('lmaccess.key');
def account = hostProps.get('lmaccount');
def alertgroup = hostProps.get('lmaccess.group');
def collectionFailures = 0
def failures = [:]
def client = new LogicMonitorRestClient(accessId, accessKey, account, this.&println)
try {
    def alerts = client.get("/device/groups/" + alertgroup + "/alerts", fields: "severity", filter: "startEpoch>:1538370000,endEpoch<:1541048399,cleared:*")
    //warnings = alerts.findAll {it.severity == 2}.size()
    println "WarningCount: ${alerts.findAll {it.severity == 2}.size()}"
    println "ErrorCount: ${alerts.findAll { it.severity == 3 }.size()}"
    println "CriticalCount: ${alerts.findAll { it.severity == 4 }.size()}"
    println "TotalAlerts: ${alerts.size()}"
catch (Throwable e) {
    failures["alerts"] = e.toString()
    collectionFailures += 1
// Do error reporting
println "CollectionFailures:${collectionFailures}"
failures.each{
    query, exception ->
        println "Exception while querying $query:"
        println exception
return 0
// HELPER FUNCTIONS //
class LogicMonitorRestClient {
    String userKey
    String userId
    String account
    int maxPages = 20
    int itemsPerPage = 1000
    def println
    LogicMonitorRestClient(userId, userKey,  account, printFunction) {
        this.userId = userId
        this.userKey = userKey
        this.account = account
        this.println = printFunction
    def generateHeaders(verb, path) {
        def headers = [:]
        def epoch = System.currentTimeMillis()
        def requestVars = verb + epoch + path
        // Calculate signature
        def hmac = Mac.getInstance('HmacSHA256')
        def secret = new SecretKeySpec(userKey.getBytes(), 'HmacSHA256')
        hmac.init(secret)
        // Sign the request
        def hmac_signed = Hex.encodeHexString(hmac.doFinal(requestVars.getBytes()))
        def signature = hmac_signed.bytes.encodeBase64()
        headers["Authorization"] = "LMv1 " + userId + ":" + signature + ":" + epoch
        headers["Content-Type"] = "application/json"
        return headers
    def packParams(params) {
        def pairs = []
        params.each{ k, v -> pairs << ("${k}=${v}")}
        return pairs.join("&")
    // Non paginating, raw version of the get function
    def _rawGet(path, params) {
        def baseUrl = 'https://' + account + '.logicmonitor.com' + '/santaba/rest' + path
        def packedParams = ""
        if(params) {
            packedParams = "?"+packParams(params)
        def query = baseUrl+packedParams
        def url = query.toURL()
        def response = url.getText(useCaches: true, allowUserInteraction: false,
        requestProperties: generateHeaders("GET", path))
        return response
    // Public interface for getting stuff.
    def get(Map args=[:], path) {
        def itemsReceived = []
        def pageReads = 0
        // Impose our own paging parameters.
        args.size = itemsPerPage
        args.offset = 0
        while(true)
            // Do da nastieh
            def response = new JsonSlurper().parseText(_rawGet(path, args))
            if (response.errmsg == "OK")
                // Catch individual items
                if (response.data.items == null) {
                    return response.data
                itemsReceived += response.data.items
                // Check if there are more items
                // if (response.data.total > itemsReceived.size())
                    args.offset = args.size + args.offset
                // else
                //     break // we are done
            else
                // Throw an exception with whatever error message we got.
                throw new Exception(response.errmsg)
            pageReads += 1
            // Check that we don't exceed max pages.
            if (pageReads >= maxPages)
                break
            if (response.data.total > 0)
                break
        return itemsReceived
If I run the URL with the API creds in my test powershell script, it works perfectly. When I test it in LM as a datasource, I get the attached error.
Quote
Exception while querying alerts: java.io.IOException: Server returned HTTP response code: 400 for URL https://XXX.logicmonitor.com/santaba/rest/device/groups/224/alerts?fields=severity&filter=startEpoch>:1538370000,endEpoch<:1541048399,cleared:*
  • I haven't tested your code but I would try doing some testing and attempt to narrow down which part exactly is causing the issue. For example does your code work fine if you remove all the parameters from the URL? And if you remove just the filter part? My gut feeling would look at the non-alphanumeric characters in your filter and there might be differences between how REST calls work in PS vs Groovy. Perhaps they need to be escaped. You might also want to simplify your code, just for testing, in case there are issues with function parameters or the like.
  • It is the > in the filter. I tried converting to htmlentities and that didn't work. I tried escaping it and that didn't work either.
    Any ideas? I am still learning Groovy.
  • Taking Mike's advice, you might just try swapping out your filter string with the URLEncoded version:
    "startEpoch%3E%3A1538370000%2CendEpoch%3C%3A1541048399%2Ccleared%3A*"
  • 6 hours ago, Mike Moniz said:
    Since it's part of a URL you might have to use urlencode rather than htmlentieies. So ">" would be "%3C". There is also java.net.URLEncoder in Groovy. I would look at perhaps using something like pairs << ("${k}=${URLEncoder.encode(v, "UTF-8")}") in your packParams() function. https://stackoverflow.com/questions/10187344/how-to-encode-url-in-groovy
    This was it. Thank you!
    Next yeah I will work on using the encoder to fix future issues.
    @Michael Rodrigues I went with MIke's suggestion and yeah that worked. Thanks!
