drazzopardi's avatar
7 years ago
Huawei Access Controller / Wireless LAN Controller
Quite new to creating DataSources, but these are a reasonable starting point for anyone with Huawei Access Controllers
WFFGFN - Access Controller
  • CPU Used Percent
  • Memory Free Percent
  • Memory Used Percent
  • Memory Free in Megabytes
  • Memory Used in Megabytes
HPAF9X - Access Points
  • Status codes – Instance Graph
  • AP alert - (If Status code = 8(normal) or 11(standby), return 1, is anything else return 0) – Instance Graph- Alert on 0
  • Client count per AP – Instance Graph
  • Client count Top AP – Overview Graph
  • Client count aggregate for whole controller – Overview Graph
  • Discovered Property - Mac address
  • Discovered Property - Serial Number
  • Discovered Property - Model Number
G627K2 – Access Point Radios
  • Working channel – Instance Graph
  • Client count per radio – Instance Graph
  • Channel utilisation – Instance Graph
  • Radio status – Instance Graph- Alert on 2(Down)
  • Radio throughput in Mbps – Instance Graph
  • Top Radio Throughput – Overview Graph
  • Radio Work Mode
