Ye_Tao's avatar
8 years ago
how to concatenate two properties
I am trying to use two properties in REST API call ( size  and fields). Following doesn't work. Coi;d someone help on the syntax?
Ye
curl -u USER:PASSWORD https://NameOfPortal.logicmonitor.com/santaba/rest/service/services?size=1000&?fields=name,id
  • Sarah_Terry's avatar
    Sarah_Terry
    Hi @Ye Tao - You should remove the second ? character, so the URL looks like this:
    https://NameOfPortal.logicmonitor.com/santaba/rest/service/services?size=1000&fields=name,id
    Let me know if that doesn't work.
    Sarah
  • No, it doesn't work. The "fields=name,id" part seems not taken. The "&" sign seems acting as "put into background on MAC".
    Actually. with "\&", it works. Thansk
