9 years ago
How Min Max Avg are actually calculated by Widgets
My experience is more with the Gauge widget but I'm sure this applies to other as well. There are options for Min, Max, and Average for the Data Series of the Gauge widget, but if you take the same datapoint and build out 3 widgets each using one option, the numbers are exactly the same. So how is this supposed to work? Is this option ignored?
As a test I used time frames of 2 hrs, 24 hrs, and 30 days which should result in significant differences between the Min and Max at the very least, even still they are all the same.
