8 years ago
Groovy - Ignore SSL Issue
To all those out there doing groovy scripting. Looking for a way to ignore the SSL errors for self signed certificates where it doesn't match the hostname. I found some code snippets but the LM collector doesn't appear to like it too much by disabling SSL verification in a groovy script. Anyone out there run into this and have an idea on how to get around it?
[02-21 11:13:19.608 EST] [MSG] [WARN] [script-running-2::script.running:Task:232203255:{url removed}:Viptela General_:script:1:7] [GroovyScriptExecutor.execute:79] Failed to execute the script with Invocation exception, CONTEXT=, EXCEPTION=CertificateException: No name matching {url removed} found
com.logicmonitor.common.sse.utils.exception.ScriptExecutingFailedException: CertificateException: No name matching {url removed} found
at com.logicmonitor.common.sse.utils.GroovyScriptHelper.execute(GroovyScriptHelper.java:186)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.logicmonitor.common.sse.executor.impl.GroovyScriptHelperWrapper.execute(GroovyScriptHelperWrapper.java:88)
at com.logicmonitor.common.sse.executor.GroovyScriptExecutor.execute(GroovyScriptExecutor.java:70)
at com.logicmonitor.common.sse.SSEScriptExecutor$ScriptExecutingTask.call(SSEScriptExecutor.java:263)
at com.logicmonitor.common.sse.SSEScriptExecutor$ScriptExecutingTask.call(SSEScriptExecutor.java:242)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.security.cert.CertificateException: No name matching {url removed} found
at sun.security.util.HostnameChecker.matchDNS(HostnameChecker.java:221)
at sun.security.util.HostnameChecker.match(HostnameChecker.java:95)
at sun.security.ssl.X509TrustManagerImpl.checkIdentity(X509TrustManagerImpl.java:455)
at sun.security.ssl.X509TrustManagerImpl.checkIdentity(X509TrustManagerImpl.java:436)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:200)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1496)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:216)
