1 Reply
- Joseph_SkupniewFormer Employee
Hi Nick,rnCurrently, there is no way to change the way that this is displayed in your Host graph view. But if you would like to, you can workaround this by recreating a new top 10 least busy graph as a dashboard graph by creating a custom graph and manually specifying the volume instances that you would like to analyze.rnYou can use the wrench icon > edit datasource definition > and then look at the Overview Graph definition in the left-pane to see how this overview graph is created so that you can use this as the basis for creating your Custom Graph.rnBest,rnJoseph Skup | Support Engineer, II
