Peter_Brischett's avatar
8 years ago
Collector IP address / Interface
Is it possible to specify an IP address or interface that the Collector should use for ping and website checks?
The server that I have a Collector on has 2 IP address, for general network and a second for iSCSI connected to a storage network.
I'm getting a few false alarms because the collector is trying to ping using the iSCSI IP address.
Anyone know of a solution rather than moving the Collector to another server?
  • Perhaps you can use routing tables on the collector host itself? At the OS level.
  • I understand what you're sating but the iSCSI interface on my server doesn't have a default gateway assigned. Windows wouldn't normally be using it try and send traffic to a routed IP address.
    My only thought is that LogicMonitor is forcing this interface to be used.
  • Hmm not sure, wouldn't expect collector/java to force an interface. I didn't see anything obvious in the collector config files either.
