Brandon's avatar
Brandon
8 years ago
CMC Blade inventory
This datasource does not provide any monitoring or alerting data.  Once applied, it will gather information pertaining to each drac-enabled blade in the Chassis.  This is useful for inventory purposes.
*Note - in order to use this datasource, you must assign the CMC login credentials to the CMC using the properties idrac.user and idrac.pass.  Remember that both the username and the password are case-sensitive.  Using the root account is NOT recommended.
W96MYH
