Joe_Tran's avatar
Joe_Tran
Icon for Advisor rankAdvisor
9 years ago
Built in aggregation options for Get Data APIs
I'm on hour 17 of a run of a script that pulls down Service responseTime data for about 345 services so I can come up of an average across all of those services from the last quarter.
I would love, LOVE a built-in option or parameter to aggregate this data in the API call. :S
  • Sarah_Terry's avatar
    Sarah_Terry
    Hi Joe,
    Thanks for the request - we'll look into it!  Are you making this type of calculation for device datapoints as well? (e.g. averaging a key performance metric across multiple servers all supporting the same service).  And is this something you'd want to visualize in a LogicMonitor dashboard widget / report, or that you're pulling into another tool?  Just trying to get a bit more context re the use case :)/emoticons/smile@2x.png 2x" title=":)" width="20">
    Sarah
  • Hi Sarah,
    As far as I know, I should be able to visualize aggregate device data using a Custom Graph widget. This is something that is lacking for Services though.
    My coworkers in the business analysts teams do import LogicMonitor data into Tableau.
    Joe
