Something like...
Alert : Critical Alert
Alert Type : Windows Event
Customer : XYZ
Time : 14:00
This alert would go to support email & Bob SMS
- Steve_FrancisFormer Employee
If you go to a host in the hosts tab, select the tool next to an Event Source, and pick Manage Alerts, there is a button Show Alert Routing on the form that pops up. This does (I think) exactly what you are asking for.
Correct me if I'm misunderstanding...
Thanks for the reply, yes i have seen that feature before and it does indeed give me the information i need, however you have to go hunting a bit for it. It would be great to be able to simulate an alert and then see which alert it triggers. It's not an essential requirement but would be a great feature in my book.
The "Show Alert Routing" is nice, but it only lets you act on one data point for one instance at a time. I'd like to have an API call that would run every data point for every instance through the same simulation and report back to me a graph representation (maybe in the DOT language how they're all connected. Then I can filter and visualize this on my side.
I started a chat under ticket 119191 and discussed this with Seth. I would like to +1 this for your next roadmap. I want to be able to see what alerts "would fire" without enabling the alerts. If I add 10 devices, I want to QUICKLY see how many would fire if I enabled them. No hunting, no slow rollouts.
Maybe a report with applied thresholds and current values with clear indicators what alert level the value is within at the report runtime.
- Mosh
Professor
Would be nice to have a form in the Alert Rules section where we can do tests.
