tuco's avatar
tuco
6 months ago
How could I add my other monitoring checks like OS, SQL and third party software to ec2 instance?
I recently added our cloud resources to logic monitoring. However we need to add more monitoring checks that were registered under our local collector server. How could I add my other monitoring checks like OS, SQL and third party software to ec2 instance?
  • Hi Mike,
    Could I use my existing local collector?  Apparently, I have existing collector but since I can integrate  AWS cloud I added ec2 resources to LM. Will that work?
    • Mike_Moniz's avatar
      Mike_Moniz
      You can use an existing collector as long as it can reach the AWS resources (servers) over the network. Would be best if the collector server itself is in AWS.
      I don't suggest adding ec2 instances into LM as normal devices as that can lead to duplicates. You would assign the local collector in the LMCloud setup as detailed in the link. That will add the other DataSources (cpu, memory, disks, etc to the existing ec2 device in LM. So it looks something like this:
      • tuco's avatar
        tuco
        Hi Mike,
        I tried following the link you provided to me unfortunately it says value unspecified. Screenshot attached
