Fail to get the script result
Hi All,
I am getting this error in CPU when doing a poll.
Fail to get the script result - Unable to execute the script for 10.203.29.94's Microsoft_Windows_CPU - java.lang.NullPointerException: Cannot get property 'PERCENTPROCESSORTIME' on null object
System Uptime in Host Status is also not working.
It gives me data in disks, memory and processes and can ping as well.
Thanks for your help.
henryrob
1 comment
·2 years agoI would suggest going thru LM's WMI troubleshooting guide at https://www.logicmonitor.com/support/monitoring/os-virtualization/troubleshooting-wmi, especially the WBEMTEST testing step and check that you can get any results from Win32_PerfRawData_PerfOS_System directly. If I was going to take a blind guess, you may need a WMI Counter Repair since other checks work.
