Azure Cloud Monitoring Question (M365/Sharepoint)
As an MSP employee trying to monitor Azure resources for a client, I need guidance on the setup process. Do I need to purchase specific Azure subscriptions to integrate a cloud account into LogicMonitor, and can I monitor multiple Azure tenants using a single enterprise application?
agonzalez
3 comments
·2 years agoI don't deal with billing myself but I believe native cloud monitoring like Azure Cloud and M365 in LM is an LM add-on and priced differently than normal devices. Best to talk with your LM Rep on the specifics for your contract. I don't believe you need to have an actual "Subscription" in Azure itself to do this, as App Registration is part of Entra ID and not subscription cloud services. I can't confirm this though.
The directions for monitoring M365 is located at https://www.logicmonitor.com/support/monitoring/applications-databases/microsoft-office-365-monitoring and for Azure Cloud services it's at https://www.logicmonitor.com/support/lm-cloud/getting-started-lm-cloud/2b-adding-azure-environment-logicmonitor. They do have you add LM as a App Registration in your tenant. I believe you can use the same registration for both.
