Internal Webchecks - Unable to use WebProxy
Summary: Brad LeClair is facing issues with implementing internal web checks using a web proxy in Groovy scripts with LogicMonitor. Despite attempts to alter the script and configuration, the script fails with an error message and does not perform the request. They seek advice on how to successfully perform an internal web check using an internal proxy server.
We have been trying to implement an internal web check using a web proxy (no auth needed)
Initially we tried using the groovy script addition of
setProxy(String hostname, int port, String schema)
eg setProxy("proxy.test.com",9090, "HTTP")
reference: Executing Internal Web Checks using Groovy Scripts - LogicMonitor
No matter what we do the groovy script fails immediately.
Then we tried modifying the LogicMonitor configuration file to force LogicMonitor to use the proxy server. Now LogicMonitor communicates out via the proxy --- except the internal web checks which continue to go directly out to the internet.
No matter how we try to alter the groovy script it returns: "Error Script did not perform any request at all."
Our original generated script that works fine:
import static com.logicmonitor.service.groovyapi.PostDataType.*;
import static com.logicmonitor.service.groovyapi.StatusCode.*;
import com.logicmonitor.service.groovyapi.StatusCode;
import com.logicmonitor.service.groovyapi.AuthType;
import com.logicmonitor.service.groovyapi.LMRequest;
LMRequest request = new LMRequest();
request.useHttp1_1()
.followRedirect(true)
.needFullpageLoad(true)
.get();
return LMHttpClient.request(request);
Adding proxy command breaks groovy script
.setProxy("proxy.test.com",9090,"HTTP")
.get();
Any suggestions on how to get an Internal Web Check to work with an internal proxy server?
