Spring Feature Spotlight
Resource Property and Instance Description Display in Table Widgets
First, we’re bringing something new to the Table… Widgets, to be exact. With an updated Resource Property and Instance Description Display function, you can seamlessly display metric and non-metric data, including valuable resource properties, in custom and dynamic tables. Incorporating instance descriptions using the ##DSIDESCRIPTION## token enhances your insights even more, giving you a more comprehensive view of your data at a glance.
Filtered and Shared Widgets in Dashboards
Now, let’s delve into our new Filtered and Shared Widgets. This highly anticipated feature allows you to set filters at the dashboard or dashboard group level, eliminating the need to create multiple dashboards. Instead of resorting to the Command or Control + F hack, you can now seamlessly filter directly within your widgets, making data analysis and action swift and convenient. This powerful functionality not only respects role-based access controls but also seamlessly integrates with our product's unified experience, creating scalability and consistency across the platform.
Usage Reporting for APM Traces and Synthetics
Unlock powerful insights with our new Usage Reporting for APM Traces and Synthetics. This feature empowers you to easily track and manage the cost of your simulated user interactions with Synthetics, AND gain visibility into your application's real-time performance data usage with Traces. Both features offer detailed account-level reporting with interactive visuals, making it easier to optimize your monitoring strategy and allowing you to make data-driven decisions about your application's performance management.
Supporting Docs - Synthetics
Supporting Docs - Tracing
ServiceNow Work Notes Integration
We released our amazing Service Now Integration in the Fall of 2023, and now we're making it better. With the new Work Notes integration capabilities, you can have a seamless incident management experience without leaving your platform.
We hope you love our Spring Feature Spotlight as much as we do. Come back for the Summer Feature Spotlight next quarter!
Note: all listed features are only available in our new User Interface. For more information about toggling, visit our LogicMonitor New UI Documentation.
Michael Raymond
·2 years agoLove this format! 🔥
Suzanne Shaw
Admin2 years agoAwesome insights, Sky, thank you so much for sharing and calling out these helpful features!
