LM API v3 Python boilerplates
In light of the coming sunset of v1 and v2 of LM API, I decided to start updating some of my own scripts.
I ran successful tests of these python boilerplates with v3: https://github.com/krshearman/LMAPI_v3
I hope it helps someone get started using LM API v3!
5 comments
David_Torres
·3 years agoThese are really helpful, thanks Kendall
kendall
OP3 years ago@mandy1193 ~ try again, it should be publicly available now. Hope it helps!
Amanda Cook
·3 years agoI am not able to see your repo for this? Is it still up? I was kinda referencing it but no worries if it’s not. Just not a ton of PowerShell examples out there. Thanks! @kendall
kendall
OP3 years agoOr just use the SDK.
Just providing an alternative quick start to the SDK for those just starting out with the api. 🙂
·3 years agoOr just use the SDK.
