Monitor Cisco dial‑peer “busyout” via SSH (parse show dial-peer voice summary) — need DataSource/script
Summary: Sharath Ramanna, also known as Sharath Ramanna, is seeking assistance with setting up monitoring for Cisco dial-peer busyout status using LogicMonitor. Since Cisco does not provide an SNMP OID for this, they need to use an SSH-based command execution. The goal is to execute the 'show dial-peer voice summary' command on a Cisco voice gateway every 5 minutes, parse the output to detect any dial-peer in "busyout" state, and trigger alerts appropriately. Sharath Ramanna is asking the community for guidance or a sample SSH Scripted DataSource to achieve these monitoring goals.
Hi Community,
I need assistance in setting up monitoring for Cisco dial‑peer busyout status in LogicMonitor.
Cisco does not provide an OID for monitoring busyout via SNMP, so we need to achieve this using SSH‑based command execution from the Collector.
Requirement Details:
We need LogicMonitor to run the following command on the Cisco voice gateway every 5 minutes:
show dial-peer voice summaryFrom the command output, we need to identify the STAT column for each dial‑peer.
A dial‑peer can be in two relevant states:
Active
Busyout
ws busyout, LogicMonitor should trigger an alarm.Monitoring should ideally create instances per dial‑peer (TAG) so alerts are easy to identify.
Looking for guidance or a sample SSH Scripted DataSource that:
Connects to the device via SSH
Runs the command
Parses the output
Detects if any dial‑peer is in “busyout”
Generates a numeric datapoint (0 = Active, 1 = Busyout)
Raises an alert when status = 1
Attached below is an example output showing the “busyout” entries for reference.
Please let me know the best way to implement this or if any sample script/DataSource is available that we can build on.
Lloyd Bare
·7 months agoThere are several free AI platforms out there that should get you %90 of the way there. You just may have to tweak the script to fit your specific needs. I've always found it helpful to find a script that's using a similar function (SSH to run a command) for example to create a custom DS. The Cisco_CUCM_LatestBackup data source would be similar; SSH to device; runs a command; parses output to get status of latest backup.
Sharath Ramanna
OP8 months agoCould anyone please help me create a DS for this?
