How to start monitoring with oci_ modules
Summary: Jeroen Gouma, Jeroen Gouma, is experiencing difficulty in using OCI datasources. They have successfully added the correct category to the server properties, and the datasource appears on the LM screen; however, no data is displayed. Jeroen suspects that authentication may be required for LM to access OCI data but cannot find relevant instructions. They are seeking help from the community with a reference link that could guide them in fixing the issue.
Hi.
I was willing to try the OCI_ datasources which are available now, but how to get these working?
I added the correct category to my server properties. The datasource shows up in the LM screen at my server, but no data is coming up. I assume I need some kind of authentication to allow LM to read the data from OCI, but can not find it anywhere how to do that (or just overlooking it).
If anybody can share a link on how to fix, would be great.
Have a nice day!
Jeroen
Jeroen Gouma
OP5 months agoContinuing searching I found this page: https://www.logicmonitor.com/support/oci-monitoring-setup
Hope it helps
