Smarter Alerting and Alert Noise Reduction: Product Power Hour Recap
Overview
This monthβs Product Power Hour focused on a topic that continues to matter for every operations team: how to reduce alert noise without losing visibility into what matters most. The session brought together product and training experts to walk through alert tuning best practices, threshold strategies, routing guidance, topology-driven troubleshooting, and new diagnostic and remediation capabilities.
The biggest takeaway was clear: effective alerting starts with tuning before routing. Rather than sending every alert downstream and overwhelming teams, the presenters encouraged customers to use alert reports, review noisy signals regularly, and build a more intentional alerting strategy that evolves with the environment.
Key Highlights
π Start with reports before routing alerts. The team recommended using Alert Frequency and recent alert reports to identify what is noisy versus what is actionable.
π Treat alert tuning as an ongoing process. As environments scale and change, thresholds and alert strategies should be reviewed regularly instead of being treated as a one-time setup.
π Use the right threshold model for the workload. Static thresholds work well for predictable resources like disk capacity, while dynamic thresholds are better suited for changing environments such as cloud and autoscaling workloads.
π Combine static and dynamic thresholds for critical systems. A hybrid model can provide both a hard safety net and early anomaly detection for customer-facing applications, APIs, and databases.
π Keep alert routing simple. Strong resource group structure reduces complexity and makes it easier to route alerts to the right team, system, or escalation path.
Leverage topology, dependent alert mapping, and new troubleshooting tools. Automated diagnostics, remediation workflows, correlated metrics, and topology edge status can help teams identify root cause faster and reduce alert storms.
Q&A
Q: Does our LogicMonitor alert policies fully cover our Azure architecture, including dependencies such as load balancers, VNets, SQL MI, application gateways, and managed PAS services? Enhancement planned?
A: Yes. LogicMonitor attaches built-in logic modules to those Azure and cloud components. Some of those modules include default alert thresholds, and if they do not, or if the defaults are not right for your environment, you can customize them.
Q: Is there a report that lists static threshold modifications below the module level so admins can see where thresholds were changed from default?
A: Yes. You can use the alert threshold report for that. If you have a large environment, you may need to filter by resource group or narrow the results. You can also use audit logs to see who changed what.
Q: Do we have some real-time use cases as templates or ready-to-go settings that we can utilize for alert thresholds?
A: Yes. The default thresholds built into logic modules are the starting point. They are based on LogicMonitor and customer experience, but you should still review and tune them for your own environment.
Q: If you update logic modules, will you lose historical data?
A: There is potential for that, depending on what changes in the module. That is why it is important to review the impact before updating. LogicMonitor does provide ways to compare the current and new versions before you apply changes.
Q: Are automated diagnostics and remediation included in platform pricing, or is there additional pricing?
A: It is included in the newer platform packages: Essentials, Advanced, and Signature. For other package types, it may require an add-on.
Q: Does LogicMonitor automatically detect GeoIP or geolocation for servers in a hybrid infrastructure?
A: Not automatically, based on the discussion in this session. You would typically need to set that location property yourself, usually through CSV upload, APIs, or a custom logic module.
Q: How can we restore a module after an update?
A: The best practice is to clone before updating. There is also a revert option in the module toolbox that lets you compare versions and roll back changes.
Customer Call-outs
βοΈ βI like that [geolocation] custom module option that you mentioned.β
What's Next
π 1H Announcement Webinar
Join us for the 1H Announcement webinar, which will serve as the official public presentation of the release themes and product updates previewed during this meeting. This will be the broader launch moment for the autonomous IT story, upcoming innovations, and related release details.
May 12 at 12 PM CT
π Register here
β‘οΈ Product Power Hours
Detect Digital Experience Issues Earlier with Catchpoint
A Catchpoint-focused Product Power Hour is coming in May on detecting digital experience issues. This session will spotlight how teams can more effectively identify and troubleshoot user experience problems.
Tuesday, May 5 at 11 AM CT
π Register here
Optimize Cloud Spend with Confidence
The next cost optimization session is scheduled for May 19 and will cover how practitioners can turn cloud cost visibility into action and explore new cost views in Resource Explorer and Cloud Budget Alerts to help teams stay ahead of spend and act faster across multi-cloud environments.
May 19 at 10 AM CT
π Register here
π½οΈ Chicago User Group
The team is heading back on the road with an upcoming Chicago user group, featuring community conversations and field engagement with LogicMonitor experts.
May 27 at 6 PM CT
π Register here
Resources and Review
π Want to upskill? Earn your Alerts badge!
π» Review the slide deck here
πΉWatch the recording here or directly on the event page.
