Modernize Hybrid Monitoring with OpenTelemetry: Recap
Summary: A recent Product Power Hour session detailed how LogicMonitor's new OpenTelemetry (OTel) Metrics capabilities enhance hybrid monitoring using open, vendor-neutral telemetry standards. Participants learned about configuring OTel collectors, high-frequency data capture, and integration into LogicMonitor dashboards and alerts. Key discussions focused on deployment configurations, compatibility with existing systems, metrics dashboard integration, and plans for future OpenTelemetry expansions, including logs support. The session emphasized scalability without major environment redesigns and addressed FAQs regarding collector configurations, alerting processes, and telemetry integration challenges.
Overview
In this month's Product Power Hour, we explored how LogicMonitor's new OpenTelemetry (OTel) Metrics capabilities help teams modernize hybrid monitoring with open, vendor-neutral telemetry. Through a live demonstration and customer use cases, we walked through configuring OTel collectors, capturing high-frequency metrics, and turning that data into actionable dashboards and alerts within LogicMonitor.
Key Highlights
⭐️ Expand visibility with OpenTelemetry: Collect metrics across Linux, Kubernetes, cloud infrastructure, applications, and network devices using open standards.
⭐️ Capture events traditional polling can miss: Use high-frequency streaming telemetry to identify short-lived performance issues, including BGP flaps and packet drops.
⭐️ Bring OTel into existing workflows: Query metrics, build dashboards, and configure threshold-based alerts that feed into LogicMonitor and Edwin AI.
⭐️ Scale without redesigning your environment: Customer beta deployments demonstrated OTel ingestion at scale, including 58 billion monthly data points, visibility into 70+ Linux servers, and streaming telemetry across 3,000+ network devices.
Q&A
Collector Configuration & Deployment
Q: Do we need to upgrade or replace our existing LogicMonitor Collector to use OpenTelemetry?
A: No. OpenTelemetry uses a separate telemetry pipeline from the standard LogicMonitor Collector. You do not need to upgrade your existing collector to enable OTel ingestion.
There are three supported configuration paths:
LM OTel Collector: Deploy LogicMonitor's collector for a more managed experience with curated receivers, processors, and exporters.
Open-source OTel Collector: Use an existing OpenTelemetry Collector and configure an additional exporter to send metrics into LogicMonitor.
Native OTel sources: Connect supported platforms or applications that already emit OpenTelemetry data.
You can access these options through the OpenTelemetry Metrics configuration page in your LogicMonitor portal.
Q: Can the LM OTel Collector run on the same host as our standard LogicMonitor Collector?
A: Yes. Both collectors can run on the same host without requiring you to replace your existing deployment.
However, we recommend avoiding duplicate collection of the same metrics through both pipelines. If both collectors monitor the same device and collect the same data, you may generate redundant telemetry.
Choose the collection method that best fits your monitoring requirements, or divide responsibilities between the two collectors to avoid unnecessary duplication.
Q: We currently monitor Linux servers through SSH polling. How would OpenTelemetry work in our environment?
A: OpenTelemetry uses a different collection model from traditional SSH polling. Rather than relying on your existing LogicMonitor Collector to periodically retrieve metrics, you can use an OTel-based approach to collect and transport telemetry.
For Linux environments, you have two primary options:
OTel host metrics: Install and configure an OTel Collector on the Linux host to collect CPU, memory, disk, network, and other system metrics.
Prometheus Node Exporter: Expose host metrics through a Prometheus endpoint and configure an OTel Collector with a Prometheus receiver to scrape that endpoint.
For larger environments with hundreds of Linux servers, we recommend working with your account team to evaluate deployment architecture and configuration requirements.
Q: Can we use OpenTelemetry for streaming telemetry from network devices such as Cisco or Arista?
A: Yes, provided a compatible receiver is available for the device and protocol.
During the demonstration, we used the YANG gRPC receiver to collect telemetry from Cisco devices at 10-second intervals. This provides greater visibility into changes that can occur between traditional polling intervals.
For Arista environments using gNMI, an OTel-based collection approach would be needed rather than the standard LogicMonitor Collector. Receiver compatibility and deployment architecture should be validated for your specific devices, particularly at larger scales.
Metrics, Dashboards & Alerting
Q: Can we reuse our existing dashboards and alert rules with OTel metrics?
A: Not directly today. OTel metrics have their own query-based configuration workflow, so existing resource-based dashboard configurations and alert rules cannot currently be reused automatically.
You can, however, create dashboards using OTel metrics and configure threshold-based alert rules directly from Metrics Explorer.
OTel alerts also appear within the existing LogicMonitor alert interface, support scheduled downtime, and feed into Edwin AI.
We're exploring greater parity with resource-based monitoring, including out-of-the-box dashboards and alert configurations.
Q: How quickly can an OpenTelemetry metric generate an alert after ingestion?
A: OTel alerting is query-based. Once a metric is ingested, LogicMonitor evaluates the configured query against its threshold to determine whether an alert should be triggered.
During the session, we discussed an evaluation interval of approximately one minute. However, the exact evaluation timing was not confirmed and requires additional validation.
The ingestion frequency and alert evaluation interval are separate considerations. Collecting telemetry every five or ten seconds does not necessarily mean an alert will trigger at that same frequency.
Q: Can we configure no-data alerts or require multiple consecutive threshold breaches before triggering an alert?
A: Not with the same level of configuration currently available for resource-based monitoring.
We're working toward supporting more of the alert tuning capabilities practitioners already use, including:
Detecting missing telemetry after a specified period.
Requiring consecutive threshold breaches before raising an alert.
Improving parity between OTel alerting and standard resource-based alerting.
These enhancements are part of our ongoing development and are not currently available in the demonstrated OTel Metrics workflow.
Q: Why were there gaps in some of the demonstrated metrics, and how can we determine whether the issue is with the source or collector?
A: Gaps appear when telemetry stops arriving. This could happen because a device stops sending metrics, a collector becomes unavailable, or another issue interrupts the telemetry pipeline.
We intentionally preserve those gaps rather than filling them with assumed values, so you can identify periods when data was unavailable.
To troubleshoot, start by checking your collector and source configuration. The LM OTel Collector provides a more managed experience, while open-source collector deployments may require reviewing debug logs to identify failures.
We're also exploring additional ways to distinguish source-level telemetry interruptions from collector issues.
Q: Can OpenTelemetry metrics be associated with existing LogicMonitor resources and topology maps?
A: Not yet. OTel metrics are currently accessible through Metrics Explorer, but they do not automatically populate the existing resource tree or topology maps.
We're working toward identifying resource information from OTel metric attributes, such as hostnames and other identifiers, to connect that telemetry with existing resources.
The goal is to bring OTel data into familiar workflows, including Resource Explorer, services, and topology, so practitioners can investigate infrastructure relationships without switching between separate monitoring views.
Licensing, Integrations & Optimization
Q: Does OpenTelemetry require a separate license or consume our existing LM Logs allocation?
A: OTel Metrics is supported through LogicMonitor's platform packaging and consumes Hybrid Units.
It does not consume your existing LM Logs allocation. Your available Hybrid Units can be allocated toward OTel metrics based on your environment's requirements.
For specific capacity planning, licensing allocations, or account enablement, we recommend connecting with your LogicMonitor account team.
Q: Can we filter unwanted OpenTelemetry metrics before ingestion to reduce data volume and Hybrid Unit consumption?
A: Yes. You can configure filtering directly within the OTel Collector's processing pipeline before metrics are exported to LogicMonitor.
The collector supports filtering based on metric names, attributes, and matching conditions, including regular expressions.
This allows you to discard unnecessary or noisy metrics before they reach LogicMonitor, helping control data volume and resource consumption.
We're also exploring ways to expose more of these filtering capabilities through the LogicMonitor UI, reducing the need to manage configurations manually.
Q: Is Juniper Mist integration already available?
A: Not yet. We've developed and tested a Juniper Mist receiver, including validation at significant scale, but it is still undergoing additional stability and security work before broader availability.
We're also working through how to incorporate the receiver into the LM OTel Collector.
Q: Are there plans to support OpenTelemetry logs in addition to metrics?
A: Yes. OTel Metrics is available today, and support for ingesting logs through OTLP is a planned expansion.
This will allow teams to use OpenTelemetry for additional telemetry types beyond metrics. A confirmed availability date was not provided during the session.
Q: What is the expected resource footprint of the LM OTel Collector, and how should we plan for larger deployments?
A: Collector resource consumption depends on the receivers, processors, exporters, collection intervals, and filtering rules you configure.
In the examples discussed, collectors operated with relatively small resource footprints, even when collecting multiple telemetry types at frequent intervals.
However, specific CPU and memory requirements, maximum supported flows, and deployment sizing depend on your workload. We recommend validating those requirements before deploying at scale, particularly for environments with thousands of monitored devices.
Customer Call-outs
⭐️ "This is fantastic."
⭐️ "Looking forward to this new development!"
Additional Resources
Ready to explore OpenTelemetry in your environment? Check out the resources below:
Review the slide deck here
