Workarounds for long ConfigSources?
I have a couple of devices where the Configis so long that the FortiOS Config shows “...Data Truncated...” in both the UI and the download. I looked in the code and so I know the limit and see that the ConfigSource is checking for a specific max size and displaying as much as it can (carving out room for the truncation message).
Anyway, I’m assuming this is some UI limit, or else LM’s code would have just printed sections back to back, until done.
So I’m wondering if anyone in the community has had the issue, and if anyone has a workaround?
Lewis_Beard
3 comments
Kwame Armstrong
·2 years ago@Lewis Beard
Let me see what I can find out regarding any UI limitations.
Kwame Armstrong
·2 years agoHi, @Lewis Beard
This is interesting. I assume this isn’t the first time this has come up.
Can you confirm what the size of the config file is? Monitored configuration files cannot exceed 3MB in size per individual file.
https://www.logicmonitor.com/support/logicmodules/articles/creating-a-configsource
