Workarounds for long ConfigSources?
I have a couple of devices where the Configis so long that the FortiOS Config shows “...Data Truncated...” in both the UI and the download. I looked in the code and so I know the limit and see that the ConfigSource is checking for a specific max size and displaying as much as it can (carving out room for the truncation message).
Anyway, I’m assuming this is some UI limit, or else LM’s code would have just printed sections back to back, until done.
So I’m wondering if anyone in the community has had the issue, and if anyone has a workaround?
Lewis_Beard
3 comments
Kwame Armstrong
·2 years ago@Lewis Beard
Let me see what I can find out regarding any UI limitations.
Lewis_Beard
OP2 years agoYes, I did notice in the code that the size is 3145728 minus the size of ("...Data Truncated...") minus the size of (a line separator), And the user confirmed to me that their config files are more than that for a couple of their devices.
So I suppose thats it, then. I would be tempted to make a custom one and just grab and display it in chunks, but maybe the UI itself has a limit. Hmm.
Kwame Armstrong
·2 years agoHi, @Lewis Beard
This is interesting. I assume this isn’t the first time this has come up.
Can you confirm what the size of the config file is? Monitored configuration files cannot exceed 3MB in size per individual file.
https://www.logicmonitor.com/support/logicmodules/articles/creating-a-configsource
