Volume Capacity - Dynamic Threshold
Apparently I have started (enabled) the Dynamic Threshold on the Volume Capacity but I could not find where it was changed initially... I thought it was only on a specific device but I start to see more alerts coming out...
Please click the following URL to acknowledge the alert (or paste it to the browser)
The filesystem M:\ on host SIPEEGFS1 is now 51.1644 percent used placing the resource into warn level, as of 2022-04-06 19:44:05 PDT.
Please free up some space, or adjust the thresholds for this volume.
This state has existed for 0h 0m.
Alert Description: Alert triggered by dynamic threshold: 100 percent of values of datapoint PercentUsed for last 5 polls deviated from upper band or lower band by a factor of 1.50, triggering in a warning alert
- I need to find out where it was enabled.
- I need to disable the dynamic threshold
Dom
Justin Dietz
·4 years agoI could be wrong but i just went into one of my Volume Capacity alert tuning and enabled it. Then i reviewed the Audit Log to see what the message was that logged. Search your audit log for a message containing the following ....
"Enabled Trigger alerts on datapoint PercentUsed for dynamic thresholds"
This found the log that I generated turning this on. Hope this helps.
