virtual datapoint - how to preform expression valuation if statement
Hi Community,
I'm trying to create a complex datapoint that evaluates NAN values as 0 (Zero) using the documented information from logicmonitor and cannot find example or explanation of how to evaluate expression in the if statement.
> according to this - Complex Datapoints | LogicMonitor i can create an if statement and evaluate it like this:
if(or(un(Datapoint1), un(Datapoint2)), unkn(), <expression to evaluate>)
So how do i evaluate against greater than Zero? I have tried may basic operations within the <expression to evaluate> area with no success.
if(un(datapointX),0,datapointX, > 0) <--- this does not work
myStatus = 1;
else
myStatus = 0;
return(myStatus);
Thanks in advance for your assistance.
Darren
·4 years agoWhat you need is a nested if statement.
if( un(DatapointX), 0, if( gt(DatapointX,0),1, -1))
This means:
if(
un(DatapointX), <-- this is your condition (conditionA)
0, <-- return this if conditionA is true
if( <-- do another if statement if conditionA is false
gt(DatapointX,0), <--We know conditionA is false, let's do another condition (conditionB) , in this case if DatapointX is greater than 0.
1, <--return this if conditionB is true
2 <-- return this if conditionB is false
Darren_Dudgeon
OP4 years agoMnagel,
Thank-you for the quick and appropriate reply and the information on PRN/groovy - that helps.
It would certainly be great if there was better documentation for this. I have tried your syntax and tried a few modifications to it as well without success.
Unfortunately i still get invalid syntax in all formulations i have tried.
·4 years agoThe operators in this mini-language are a bit incomplete and I get annoyed regularly. For example, there is no negation (not) and there is no ne (not-equal) condition. You can workaround it, but it is a weird miss.
You also cannot format it the way shown, though -- it has to all be RPN (reverse polish) or (possibly) all groovy code. See https://www.logicmonitor.com/support/logicmodules/datasources/datapoints/complex-datapoints for an overview.
This should work for your example (I think -- it is untested other than verifying parens match):
if(un(datapointX),0,if(gt(datapointX,0),1,0))
