Two switches, same hardware, same sw version, same snmp config - one works, one don't
Hi folks,
Another wired situation: I has two switches, same hardware, same sw version, same snmp config - one works, one don't. I can add one switch as device without any issue, the other one can't because of snmp issue.
Had anyone seen similar problem? Any suggestion to resolve the issue?
Thank you very much!
Keith
netcruiser
1 comment
·6 years agoHave you had a chat with support? Off the top of my head I would ask about the difference between the network paths between the collector and the switches. Have you tried doing a ping and SNMP GET from the command line (should be built into most Linux distros and there's a third party version you can use in Windows). Should at least verify if the problem is LM or if it's specific to your environment.
