Tomcat/JMX monitoring with SSL
Has anyone enabled SSL on JMX and gotten it to work ?
Following directions on Tomcat | LogicMonitor, I can make it work with authentication but "com.sun.management.jmxremote.ssl=false"
If I set that to true I'm getting
"Fail to get the jmx result - java.rmi.ConnectIOException: error during JRMP connection establishment; nested exception is: javax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure"
I have also tried to pass "Djavax.net.ssl.keyStore" and "Djavax.net.ssl.keyStorePassword" with no luck.
SSL to my web page (using the same keystore) works fine so I would assume that the file is ok.. the only item I see in the catalina.out log that might have something that helps ?
"03-May-2021 12:18:05.238 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The Apache Tomcat Native library which allows using OpenSSL was not found on the java.library.path: [/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib]"
Keimond
OPSo I gave up on SSL as it turns out the behavior is not what I thought it was and we do not need it. I do have it working great with authentication which is all I need.
Now I just have to figure out why our test server works and our production server doesn't !
my setenv.sh file sources a file set up by ansible...
I've run tcpdump on the production server and wireshark back on my windows collector and verified that the two are in fact talking to each other on the jira_lm_jmxport
The error indicates that it's timing out. I tried increasing the timeout for jmx on the collector and was still getting a timeout but perhaps I need to try longer...
On Friday I'll be restarting the service after adding these two lines to see if that helps after reading some posts
Keimond
OPThanks I have reached out to support for their suggestions!
Definitely something to take up with support, if you haven't already.
