!tlist in 36.xxx+ versions of the collector
Has anyone else noticed that !tlist doesn't work in versions 36.000 of the collector and above? This is the collector that just came out of EA and is now GA.
15 comments
EvanTempel
·2 years agoRan it on 3 of our collectors on 36.x, tlist with no arguments or params. No issues.
OP2 years agohehe, LM's just messing with me personally...
Lewis_Beard
·2 years agoI dont have that vault setting at all in any of my 5 configs. And on the first one there, I dont know if you made a typo or were in a hurry or if I'm being overly picky, but mine has a "d" on the end, on ours the value is lmlogs.syslog.enabled with a d at the end. And mine is set to false, if that helps.
Lewis_Beard
·2 years agoWhen I say 5, I mean, I looked in Agent, WatchDog, Wrapper, Sbproxy, and Website ... just to be sure. I only checked a couple of different collectors, some of the ones that worked on my side.
OP2 years agoYep, i meant enabled. Was in a hurry. It would be in the agent config. As far as i can tell, those are the only differences. I'll let support know. I wonder how much faster they would find bugs like this if they just involved the community. I'm sure they could say, "hey does anyone have a collector with a, b, and c in the collector config, running version x? Could we run a debug command and grab the output or test this thing?" I'm sure with all of us someone would have a matching scenario.
Lewis_Beard
·2 years agoI just went to several other collectors, both Windows and Linux, all at 36.000, and I can't reproduce your error. At least one was a new deploy, but most of the others are all upgrades.
I cant reproduce the error, my !tlist works fine. Not sure if that helps in any way, but maybe it will.
OP2 years agoI wonder if it's something i have customized in the config. The only thing that would be on all my collectors is:
lmlogs.syslog.enable=true
vault.bypass=false
OP2 years agoWe'll see what support says. They were pretty quick to lump it into an existing bug ticket.
Lewis_Beard
·2 years agoIts an upgrade. It was deployed in 2021.
OP2 years agoInteresting. This is what I get:
Is your collector a new install or an upgrade? Mine's an upgrade. Wonder if something breaks during the upgrade that doesn't break during the new install.
Lewis_Beard
·2 years agoAnd here is an image showing I'm on 36.000 .... headed to lunch but good luck
Lewis_Beard
·2 years agoI can. When I run !tlist without params, I get back the results I expect.
I redacted the IPs but here is a shot from the command with no args.
Lewis_Beard
·2 years agoI just went to one of my collectors that is at 36.000 and I ran one of the example commands from the help (specifically: !tlist summary=datasource) and I got back meaningful results.
I haven't tried it myself but I assume the new-ish security option for "Enable Collector Debug" would (I assume?) block you from running the debug "shell" completely. I think they left enabled checked by default.
So I'm not sure what it would be, unless I'm misunderstanding.
But I can run !tlist on one of my 36.000 collectors.
OP2 years agoSupport said it was a known issue. Can you run two list without any arguments?
OP2 years ago!tlist*
