Terraform Provider 2.0.3 - 'extra' Statement Always Modifying
Using the Logicmonitor Terraform provider (version 2.0.3).
When I apply a configuration, subsequent plans/applies seem to indicate there will always be changes for an `extra` property that, by all indications, should only apply to 'cloud' resources. See example here:
<span class="pln"> # module.devices_by_region.logicmonitor_device_group.datacenters["LAB1"] will be updated in-place
~ resource "logicmonitor_device_group" "datacenters" {
id = "740"
name = "LAB1"
# (25 unchanged attributes hidden)
- extra {
- devices = [] -> null
}</span>
When I try to 'pre-fill' this property, it's just a rabbit hole of then needing to specify all of the other properties, the properties of those properties, etc, which tells me that this might just be a bug that needs to be corrected in a future release. Before opening an issue at the GitHub repo for this, I wanted to find out if anyone had better experience with Terraform in this space and could perhaps tell me of a way to work around this.
AustinC
3 comments
AustinC
OP3 years agoYep yep -- I ended up working around this specific problem with 'extra' with the following lifecycle statement:
Jeroen_Gouma
·3 years agoCreated a bug on Github: https://github.com/logicmonitor/terraform-provider-logicmonitor/issues/57
Jeroen_Gouma
·3 years agoSame here, seems like a bug indeed ?
