system.info missing in the Info on a device
I have the system.info =~ “Integrated Lights-Out 4 255 Aug 1 6 2017” on 3 machines but it is missing on 2 other machines. What do I miss in the process to get the system.info appearing on the info for a device and get populated ?
I checked the SNMP Services on each machine and the Security Tab is identical with the “Accepted community names” as well as the list of IPs in the “Accept SNMP packets from the hosts”.
What did I miss?
Dom
Dominique
2 comments
Amr Elabd
·3 years agoHi Dominique,
So the collector runs snmpget against the following OID 1.3.6.1.2.1.1.1.0 to get sysinfo on the devices its monitoring. If that call wasn’t successful for some reason, that can cause the system.sysinfo property not show up on the resource properties under Info tab.
You can run the below snmpget via collector debug to test.
!snmpget <IP/Hostname> 1.3.6.1.2.1.1.1.0
Run help !snmpget to get the available options for the snmpget command
Adding collector debug console usage article in the documentation for reference: https://www.logicmonitor.com/support/collectors/collector-troubleshooting/using-the-collector-debug-facility
If the above snmpget had a successful response, then its possible that the basic system discovery hasn’t been triggered yet. You can manually run active discovery on a device by navigating to Resources > Find the resource in question > click on the blue drop down next to the manage button > click on Run active discovery. This may get the system.sysinfo property to be populated if that was the case.
If the query failed, it could be due to many reasons such as:
- Bad credentials set in device properties, SNMP properties are listed in the following article for reference https://www.logicmonitor.com/support/getting-started/advanced-logicmonitor-setup/defining-authentication-credentials#protocol-snmp
- Collector host is missing access to the SNMP port on the monitored device (default port is 161)
- Missing access on specific OIDs on the device
The below article goes over troubleshooting of general SNMP data collection that might be helpful.
https://www.logicmonitor.com/support/monitoring/os-virtualization/troubleshooting-snmp
Feel free to submit a support ticket to get further assistance if needed
https://www.logicmonitor.com/support/about-logicmonitor/customer-support/get-support-resources
Kwame Armstrong
System.sysinfo is collected as part of our basic system information discovery process.
We run 4 queries to determine this system information (WMI, SNMP, XenServer, and ESX).
Reference article:
https://www.logicmonitor.com/support/devices/adding-managing-devices/device-properties
Might be best to submit a support ticket for us to take a closer look.
