Can some one guide on how we can ingest/import the stripe metrics in LM? Thanks in advance...
manish arora
1 comment
Looks like Stripe has an API. Seems to use bearer authentication, so it should be pretty simple. I don't have an example using bearer authentication, but I do have an example using basic authentication. A couple google searches should show how to switch over to bearer auth.
