strings in Data source/data point?
Hello
We have some data that is held in a SQL server database table that we would like to use in a dashboard. Ideally the same
data set would populate a pie chart and a small table. e.g.
We have a data source using a JDBC connection over to the SQL server and that all works, problem is that the data point does not work with
strings (in this case status).
So my question is, how can I pull all seven columns in this data set to show in my dashboard? Is there a way of doing this or
is NAN (not a number) an insurmountable block?
The data source is as follows:
The error message is NAN (not a number)
david_gray
6 comments
david_gray
OP4 years agoOMG, I really did not see that ?
Thanks Stuart.
·4 years agoAt the top of the linked page is this link to an example groovy script for MS SQL: https://github.com/sweenig/monitoring-recipes/blob/master/DataSources/Groovy/JDBC/Groovy_JDBC_MSSQL.groovy.
Line 38 has your SQL query, and lines 39-43 are where you'd have to write code to output the numbers based on the text values.
david_gray
OP4 years agoHi,
Thanks for the link.
Unless I am missing something I'm not seeing any example scripts on that link though. This one shows how to setup the JDBC connector, which we
already have, though not being an admin I cannot modify.
Is the scripted collection you mention Groovy or Powershell? We have some of these already working - setup by LM professional services, they seem to generate
boilerplate Groovy code.
Thanks
·4 years agoGoing on my list of FRs now.
·4 years agoAnd just imagine if LM added per-DP enum support so this wasn't all such a hack.
·4 years agoYou'll have to switch to scripted collection, still using JDBC. Then you can enumerate the possible values of Status and convert to a number that can be stored in the datapoint. Example script here: https://github.com/sweenig/monitoring-recipes/tree/master/DataSources/Groovy/JDBC
