Predicting Hardware failure
Hi All,
We are looking to see if logicmonitor can predict hardware failure for the devices Monitored.
Thanks in Advance
venkat
4 comments
Hi All,
Thanks in Advance
·1 year agoOne thought when you want to see if LM can do something, is work out how to determine what you want by hand first. For example, perhaps you find that Dell iLO can report on predictive drive failures. You can then use that knowledge to look at LogicMonitor's iLO DataSources to see if it checks for that specifically.
venkat
OP1 year agoyes we are looking to use the ILO datasources but specifically for windows thanks for the update let me check
Admine
·1 year agoHi Venkat,
I think you want to check the specific Logic Modules per vendor. You would need to check which vendors your hardware is coming from since you need that for early detection.
venkat
OP1 year agoI want to predict for windows server hardware failures
