PowerShell script template for API Get website/websites
I'm having some trouble getting website listing via API requests to complete via PowerShell and would welcome any feedback. This has been modified to be explicit for '/website/websites'. I have another version of the code below where $resourcepath is set to '/device/devices' and x-version is 1 that is successful but X-Version 1 fails with website requests using both tools. In Postman I can get a successful response with X-Version 3 but I'm not finding the differentiating factor between that and this script.
<span class="pln"><# Use TLS 1.2 #>
<# account info #>
$accessId =
$accessKey =
$company =
<# request details #>
$httpVerb = 'GET'
$resourcePath = '/website/websites'
<# Construct URL #>
$url = 'https://' + $company + '.logicmonitor.com/santaba/rest' + $resourcePath
$requestVars = $httpVerb + $epoch + $resourcePath
<# Construct Signature #>
<# Construct Headers #>
$headers.Add("X-Version",'3')
<# Make Request #>
$response = Invoke-RestMethod -Uri $url -Method $httpVerb -Header $headers
$response.ToString()
<# Print status and body of response #>
$status = $response.status
$body = $response.data| ConvertTo-Json -Depth 5
Write-Host "Status:$status"
Write-Host "Response:$body" </span>
Garry_Gearhart
3 comments
·4 years agoTo set the version in postman (or any API interaction), you can either set the "X-Version" header to the version you want to use:
Or you can add a query parameter called "v" to the URL and specify the version:
Justin Dietz
·4 years agoGary, after i posted the last comment i actually think i got it figured out. Looking at the swagger looks like collectorIds is something you can query on. So i looked at my websites (we have 30) and all are being monitored internally by our collector group. So i just choose a collector and added these queryparams...
Make sure you add the "+ $queryparams" on the back of your URL and let me know how you make out. I am doing this with "X-Version 2"
Justin Dietz
·4 years agoGoing off the examples on LogicMonitors website your script looks correct to me. I am also having issues using their examples successfully. I have a current open ticket with them.
Like you the same script with "/device/devices" works for me however "/website/websites" does not work. I got a 404 error.
Where did you find to use x-version 3 in postman? Not sure I have found the documentation on when to use what X-Version.
