Postman API variable use
Has anyone successfully used variables with POST calls in Postman? I'm successful with basic tests creating groups and devices (no vars) but once variables are introduced in the place of values in the JSON body, postman console shows the data values are correctly being substituted but I'm getting 1401 errors.
Garry_Gearhart
9 comments
keiransteele
·4 years agoI have come across this issue too when attempting to add an SDT to a device, it's quite frustrating. It's because the auth header is being constructed before the body has been fully constructed with other variables that are not yet known. It works if you are ok with static values.
JonR
·4 years agoThanks all. I thought something like that might be happening. The thing that still makes we scratch my head is I tried setting the ID in the pre-request script and it still didn't work. I was trying to put a collection together to ease the learning curve for some of the team. I'll just document it and let them insert their ID manually.
·4 years agoYes, I've not had any success using Postman as the thing that actually runs my API calls in production. I simply use it to figure out what my calls need to be. Once i get to the point where i need to loop through things with variables, i move to scripting. Powershell is great if that's your language. If Python's your language, consider the SDK.
Garry_Gearhart
OP4 years agoI moved to using Powershell. I believe the problem is with the body being explicitly RAW and JSON. I think it has to be RAW or maybe TEXT format to allow variable values to be referenced correctly and then converted to JSON via pre-request script but have not had a chance to test again.
The following works for me (specific to JonR's request)
Pre-request script at the collection level:
Environment variables (pre-existing):
api_id, api_key, auth, url, dvId, deviceId, dsld, datasourceName, instId (Current Value of dvId is set to a real device ID)
Get request:
{{url}}/device/devices/{{dvId}}
Authorization tab, type is inherit.
Headers tab key:Authorization, value:{{auth}} (also a good idea to set X-Version to 1 or 3 depending on what type of request for future reference. This works without it.)
Pre-request script should have no content (if you are changing device id here, the request will fail as this runs after the collection level pre-request script but before the request is sent).
JonR
·4 years agoI have what seems like a similar issue with a get operation getting a device by ID. When I set the ID manually in the request it returns a single device as expected. When I set the ID with an environment variable authentication fails with a 1401 code returned. The headers and request path look identical in both cases. Was there a resolution found for the original post?
Working request with ID 5 set statically in the request:
{{url}}/device/devices/5 sends: GET https://(company).logicmonitor.com/santaba/rest/device/devices/5
Broken request with id variable set to 5:
{{url}}/device/devices/{{id}} sends: GET https://(company).logicmonitor.com/santaba/rest/device/devices/5
I tried modifying the pre-request script as well and had the exact same results. Script modification:
·4 years agoThat's a problem with your pre-request script? It's not doing authentication right?
Garry_Gearhart
OP4 years agoThis is the raw JSON format body in the request
The postmaster console when I send shows this as the request body:
But the response body returns:
If I change the raw JSON format body back to a string
then it sends successfully and makes the group. No other changes are required in Postmaster. So if I trust Postmaster's console, the request outbound looks correct and identical with both requests.
·4 years agoAre you including the proper quotes around the variables to ensure the resulting json (after substitution) is valid? jsonlint.com?
