Post Alert API
Hi
I am looking for API to make new alert into LogicMonitor. Is it available ? There is no such API as followings.
Kiyoshi_Egawa
1 comment
Hi
·3 years agoNo, there is not really one.
If you are using LM Logs, you could post a log then create an alert pipeline then an pipeline alert. That would open an alert for you.
Alternatively, you could use push metrics to push data in and set a threshold on the metric to open an alert. That would allow you to post a clear as well.
