Office 365 monitoring
This is unofficial...On my own and on the side, I designed a DataSource to monitor Office 365 using Microsoft's API. See more on my blog http://blog.MikeSuding.com. All the usual disclaimers apply...use at your own risk. I will try to help if it doesn't work for you.
Mike_Suding
Posted 8 years ago·Last reply 6 years ago
13 comments
·6 years agoAre you using the out of the box O365 datasources? We've incorporated comprehensive monitoring into the core out of the box datasources. If you don't have them, you need to pull them into your portal.
Herin
·6 years agoHi @Mike Suding,
Trying to use the Office365 Datasource but it failing to configure
[05/19/2020 12:36:40] Connecting to AzureAD
[05/19/2020 12:36:50] Getting list of registered applications
[05/19/2020 12:36:50] Creating new App
[05/19/2020 12:36:52] App Id is 9b6b0f04-8583-407b-9283-3bbea0281005
[05/19/2020 12:37:07] Application verified
[05/19/2020 12:37:07] Disconnecting from AzureAD
[05/19/2020 12:37:07] Step 1 complete. Continue with Step2.
[05/19/2020 12:37:14] Obtaining list of devices
[05/19/2020 12:37:14] API call: https://xxxxxx.logicmonitor.com/santaba/rest/device/devices?filter=displayName:xxxxxx
[05/19/2020 12:37:15] Response code is 200
[05/19/2020 12:37:15] Deploying tokens of target app
[05/19/2020 12:37:15] Generating Oauth Form
[05/19/2020 12:40:30] Requesting Office 365 tokens
[05/19/2020 12:40:31] Response: Token type: ; Scope: ; Expires in: ; Resource:
[05/19/2020 12:40:31] Requesting Graph API tokens
[05/19/2020 12:40:31] Updating device properties, device id is 27
[05/19/2020 12:40:31] API call: https://xxxxxxxx.logicmonitor.com/santaba/rest/device/devices/27?patchFields=customProperties&opType=replace
[05/19/2020 12:40:32] Response code is 1007
Any ideas what would be causing that?
joedalton
·7 years agoHi Mike, The customer wants the O365 Audit logs monitored and a report to be submitted daily. What we currently have now is a powershell script that pulls out a csv with relevant security events. We then present a daily report based on these events. It is a bit labor intensive and I think we can use LM to automate it. I'm trying to develop a PS script to embed in a datasource to search this audit log at set intervals. If I can have LM pull these events in (not too worried about the alerting for now) I can then create a dashboard & reports. When you say test on my account, do you mean the O365 a/c? I dont have anything in LM yet as I'm still cooking a PS script to do what I need.
This is what I am currently using to pull events for the previous 24 hours.
$CreateEXOPSSession = (Get-ChildItem -Path $env:userprofile -Filter CreateExoPSSession.ps1 -Recurse -ErrorAction SilentlyContinue -Force | Select -Last 1).DirectoryName
. "$CreateEXOPSSession\CreateExoPSSession.ps1"
Connect-EXOPSSession -UserPrincipalName test@test.com
#Output files directory
$outputFile = "C:\Users\john.doe\Desktop\AuditRecords.csv"
# Set Dates
$StartDate = (Get-Date).AddDays(-1)
$EndDate = (Get-Date)
$AlertOperations = @('FileDeletedFirstStageRecycleBin','FileDeletedSecondStageRecycleBin',...............................................LOTS MORE!!!!)
Search-UnifiedAuditLog -StartDate $StartDate -EndDate $EndDate -Operations $AlertOperations -ResultSize 5000|epcsv $outputFile -NoTypeInformation -Append
EXIT
Neil_White
·7 years agoThanks for this Mike. I've Set this up and it's working great in my environment!
Keep up the good work
Mike_Suding
OP7 years ago@joedalton, What exactly do you want to monitor with regards to security? I did create a prototype for the 'risky sign-ins' and 'identity' stuff (I forgot Microsoft terminology) but I was not able to simulate/create events so I couldn't test it. If you have events that you want to detect/monitor, and are willing to let me test on your account, please let me know.
joedalton
Thanks for the offer of a meeting. I found a workaround which was to manually import the XML files. Its working away and datasources are pulling in the data.
Would you happen to know if anyone in the community has done anything on monitoring/alerting on security in O365?
BTW- the datasources are great and I definitely will have a use for them on first view.
Joe
Mike_Suding
OP7 years agoSorry @joedalton, it's easier for me to troubleshoot in a meeting. I sent you a direct message with instructions to schedule time.
joedalton
·7 years agoHi Mike
I've been looking at testing this out but continually getting API response of 1041.
The properties get populated for the device but the datasources dont.
Thanks
[05/23/2019 11:45:36] API call: https://XXXXX.logicmonitor.com/santaba/rest/device/devices?filter=displayName:xxxxxxxx
[05/23/2019 11:45:36] Response code is 200
[05/23/2019 11:45:36] Deploying tokens of target app
[05/23/2019 11:45:36] Generating Oauth Form
[05/23/2019 11:46:19] Requesting Office 365 tokens
[05/23/2019 11:46:20] Response: Token type: Bearer; Scope: ServiceHealth.Read; Expires in: 3600; Resource: https://manage.office.com
[05/23/2019 11:46:20] Requesting Graph API tokens
[05/23/2019 11:46:20] Response: Token type: Bearer; Scope: Reports.Read.All; Expires in: 3599; Resource: https://graph.microsoft.com
[05/23/2019 11:46:20] Updating device properties, device id is 383
[05/23/2019 11:46:20] API call: https://XXXXX.logicmonitor.com/santaba/rest/device/devices/383?patchFields=customProperties&opType=replace
[05/23/2019 11:46:20] Response code is 200
[05/23/2019 11:46:20] Importing Office 365 datasource template.
[05/23/2019 11:46:20] Importing DataSource.
[05/23/2019 11:46:20] API call: https://XXXXXX.logicmonitor.com/santaba/rest/setting/datasources/importxml
[05/23/2019 11:46:20] Response code is 1041
...................... all imports give 1041
Mike_Suding
OP7 years agoSorry, I don't know the solution by looking at this. I sent you a direct message a minute ago to schedule time with you.
thanks
Nav_GF
·7 years agoHello all,
reviving an old post but I was wondering if @Jason Miller or @Mike Suding found a solution to the error posted above? I'm also having the same issue and not sure what is causing it. I have made an account on Azure AD with Application Administrator and still no luck. Here is the error message:
Any help would be greatly appreciated :)/emoticons/smile@2x.png 2x" title=":)" width="20">
Nick_Conlon
·8 years agoI got this up and running in my tenant, we put a lot of restrictions in Azure so I had to use my Global Admin to setup the app. Not sure if it requires that high of a privilege but it got the job done.
Mike_Suding
OP8 years agoYes...If you can't add an application manually, I would guess you don't have an account that supports it or you don't have enough permissions.
Jason_Miller
·8 years agoI am seeing this error when trying to create the application:
I tried add an application manually and it was saying I needed Azure AD premium. Could this be a reason this is not working?
