"name": "module.ShaValueChanged", "detail": "Collector exported jar or executable is changed/modified
Hi
Can anyone give a reason for the erroe/warning in the collector modules status that says:
Thanks
MarkP
5 comments
Shack
·2 years agoUninstall/Reinstall has fixed this for me.
·2 years agoevecaviedes , if you're seeing this error, it's likely something like anti-virus is changing some of the collector's files. Make sure you exclude the program directory for the collector and reinstall the collector (grab the download for the existing collector from the collectors page).
Evelyn Caviedes
·2 years agoFYI: Updating the collector can fix the issue. It worked for me.
Joe Williams
·2 years agoI would raise a support case. But from what I am reading, something is changing core files to the collector. It could be MDR/EDR or something else.
