Move from Slack to MS Teams
We are planning to move from Slack to Microsoft Teams and therefore need to look into how we change our Slack integration alerts into MS Teams alerts.
Is there any up to date information/instructions on this?
TIA.
Jonathan_Hart
6 comments
Jeroen_Gouma
·5 years agoJonathan,
have a look into this thread on this forum also. It is a bit old, but more or less the same as I did :-).
/topic/2142-microsoft-teams/Jeroen
Jeroen_Gouma
Sorry for the delay. I was not in the office for some time.
Please see instructions below.
Open Teams and right click the 3 dots behind the channel where the notifications should appear
Open LogicMonitor webinterface and go to “Settings > Integrations”
Click <Save> and test ?.
Of course the body is customisable, but at least this one is working. Feel free to adapt according your needs.
Kind regards,
JEroen
Arafat_Aman
·5 years agohttps://github.com/kdevilbiss/Integrations/blob/master/Microsoft_Teams_v1.json?_ga=2.22433138.874832268.1628767705-365971908.1628767705
Jonathan_Hart
OP5 years ago@Jeroen Gouma
Did you manage to find your notes on this at all?
Thanks
Jonathan
Jonathan_Hart
OP5 years agoThank you! Much appreciated. I will look into it while you search for your notes.
Jeroen_Gouma
·5 years agoHi Jonathan,
This can be done. I will try to find my notes and post them here.
Meanwhile, on the LM side you have to create an Integration which posts message to http endpoint.
On the MS Teams side you need to create a webhook in the teams-channel which is used by LM to post a message
I'll let you know when I found my notes
