monitoring MS SQL 2025
anyone able to get this to work? none of the datasources work with either integrated or local accounts. i see this is not on supported list for SQL. any idea when its coming? sql server 2025 came out over 6 months ago...
BH IT
Posted 3 months ago · Edited 3 months ago·Last reply 2 months ago
2 comments
BH IT
OP2 months agoi had to change the probe to run as a windows account and not the local system.
appreciate the follow up
John Cutsinger
·2 months agoSQL 2025 worked in my tests. I have found one permission change I need to make to the LM user config docs to get access to all of the tables but I want to make sure it is needed before publishing it. What environment are you running SQL in? Is it an Azure instance?
