Meraki Cellular Gateways and Sensors
We’re planning R&D that “aims” to monitor Meraki MG Cellular Gateways and MT Sensors and to give them their own Topology Map graphics.
Please DM me if you use either of these types of Meraki devices and would like to participate in the R&D process.
Patrick Rouse
Posted 3 years ago·Last reply 2 years ago
5 comments
Patrick Rouse
OP2 years ago@Patrick Rouse - the original statement mentioned MT Sensors (e.g. Meraki MT10 Temperature and Humidity Sensors) - is this something that will be supported by a LogicModule? Sensor support doesn’t appear to be documented (as at 07 Dec 2023) per https://www.logicmonitor.com/support/cisco-meraki-monitoring#h-logicmodules-in-package
These modules are now generally available.
Patrick Rouse
OP2 years agoWe plan to release the first iteration of MT Sensor monitoring modules in the next 1-2 weeks.
Patrick Rouse
OP2 years agoMT-series sensors are next on my list of Meraki devices to support, and I anticipate bringing this functionality to market in the first half of 2024. If you’re interested in participating in the R&D as an early access tester, please email me at first dot last at logicmonitor.com.
In addition to on our website, our current Meraki monitoring features are listed/shown here:
https://apps.meraki.io/en-US/apps/420402/logicmonitor-%7C-lm-envision#features
ddkonline
·2 years ago@Patrick Rouse - the original statement mentioned MT Sensors (e.g. Meraki MT10 Temperature and Humidity Sensors) - is this something that will be supported by a LogicModule? Sensor support doesn’t appear to be documented (as at 07 Dec 2023) per https://www.logicmonitor.com/support/cisco-meraki-monitoring#h-logicmodules-in-package
Patrick Rouse
OP2 years agoModules for monitoring Meraki MG Cellular Gateways are now generally available. They monitor both signal power (RSRP) and signal quality (RSRQ), reachability, and include (in v197) a new Cellular Gateway topology map graphic.
