LogSource Resource Mapping Confusion
I have a ticket opened but hoping to get a quicker response here.
I am using LogSources but since we are an MSP with multiple clients, there seems to be an issue syslog's are being mapped to other client devices that have the same IP because I'm using IP=system.hostname as the mapping.
I have even pointed all the duplicate IPs to their respective syslog collector and it still maps wrong.
Am I doing something wrong or is the system not smart enough to know that it came on this collector, therefore I should only map it to resources monitored by that collector?
Is there a way I can use AND logic with the Token mapping for _lm.collectorId = system.collectorid?
Thanks in advance.
Justin Lanoue
6 comments
·2 years agoOn purpose, it ignores the collector assignment. This is because you might want the logs coming in on one collector and the collection happening on a different collector, to distribute the load.
FWIW: we don't use IP=system.hostname. Instead we use IP=system.ips. However, I can't be sure that one customer's logs aren't showing up under a different customer. Now I have to check and I'll be following for a solution.
Justin Lanoue
OP2 years agoI found using system.ips was way worse as it opened a broader scope to duplicate IPs.
I understand but even then, there should be logic to know the collector and the device both have the system.tenant.identifier property or something.
I'll definitely update this thread if I get a solution from support.
·2 years agoOn the device, you can check a box that says "Enable LM Logs" which will give you the ability to specify a collector group and collector. That may be how it's done.
Now i gotta go figure out how to script it so that all devices have it checked and set to the collecting collector.
Justin Lanoue
OP2 years agoYeah I know about that option which is what I was refencing in the opening and that doesn't work.
I seem to have fixed this issue though with my own experimentation with the below settings.
This got devices mapping properly with duplicate IP as seen below.
It went from the wrong core switch to the proper Sophos XG device that shared the same IP.
No clue how this works as if knows the deviceID the log is coming from why even have all this IP mapping shenanigans?
·2 years agoYeah, i have another thread somewhere talking about the completely illogical nature of the circular logic between appliesto of a logsource and the mapping.
FWIW: I'm about to roll out this script, which should make sure that every device in my portal has the log collector configured as the preferred collector. I could have set to be the current collector, but in a failover situation, the logs will still be going to the original collector.
Justin Lanoue
OP2 years agoJust tested and it completely works with just the deviceID mapping...
That baffles me as the default LogSource LM provides you is this config below which make it seem like even they don't know how it works.
