LogicMonitor Data Publisher for HTTPS Receiver: No data being sent
Summary: David Bond is encountering issues with setting up the LogicMonitor Data Publisher for an HTTPS Receiver. They are using a v40.000 collector and have configured the agent.conf file with collector-publisher settings. Despite the setup, no data is being emitted, and the logs show warnings about attributes not found or collected. Edward McGowan suggests that David Bond open a support case to address the issue. Additionally, David Bond requests approval for their question from a participant name @Sky Donnell.
We are trying to set up the LogicMonitor Data Publisher for HTTPS Receiver using documentation at https://www.logicmonitor.com/support/logicmonitor-data-publisher-for-https-receiver
We have a v40.000 collector, configured as follows in the agent.conf:
However, no data is emitted.
In the logs:
==> /usr/local/logicmonitor/agent/logs//wrapper.log <==
[2026-06-05 14:13:40.559 GMT] [MSG] [WARN] [collector-task-thread-collector.jmx-jmx-25-28::collector.jmx:Task:273109111:127.0.0.1:jmx:LogicMonitor_Collector_Publisher::1] [JMXTask.getAttributesPreferBatch:599] Some attributes not found in batch mode, CONTEXT=count=1, objectName=LogicMonitor:type=Publisher, attributes=[com.santaba.common.util.Pair@3a849dcc]
[2026-06-05 14:13:40.560 GMT] [MSG] [WARN] [collector-task-thread-collector.jmx-jmx-25-28::collector.jmx:Task:273109111:127.0.0.1:jmx:LogicMonitor_Collector_Publisher::1] [JMXTask._getAttributesOneByOne:492] Get jmx data failed, CONTEXT=objectName=LogicMonitor:type=Publisher, attribute=sizeOfBigQueue, error=RuntimeOperationsException: Exception invoking method sizeOfBigQueue
[2026-06-05 14:13:40.560 GMT] [MSG] [WARN] [collector-task-thread-collector.jmx-jmx-25-28::collector.jmx:Task:273109111:127.0.0.1:jmx:LogicMonitor_Collector_Publisher::1] [JMXTask.getAttributesPreferBatch:642] No attributes are collected by oneByOne - disable oneByOne in prefer batch mode, CONTEXT=notFoundCount=1
[2026-06-05 14:15:40.560 GMT] [MSG] [WARN] [collector-task-thread-collector.jmx-jmx-25-13::collector.jmx:Task:273109111:127.0.0.1:jmx:LogicMonitor_Collector_Publisher::3] [JMXTask.getAttributesPreferBatch:599] Some attributes not found in batch mode, CONTEXT=count=1, objectName=LogicMonitor:type=Publisher, attributes=[com.santaba.common.util.Pair@2af087cf]Any ideas?
David Bond
OP3 months ago@Edward McGowan No. I keep trying to register for support, and I'm told that I will receive an email. I don't. This is why I must resort to obtaining support via the community.
If possible, please answer the question here. This is required by one of your biggest customers worldwide, and we're trying to provide them with a solution.
Edward McGowan
·3 months agoHi @David Bond - could you please open a support case for this issue?
David Bond
OP4 months ago@Sky Donnell - Could this question be approved please?
