LM Collector behind a Fortinet Firewall
For security reason a collector has to be behind a Fortinet Firewall, i mean between the collector and the LM data center. I have to determine the FW requeriments in terms of throughput and sessions number in order to be able to work flawlessly with 500+ devices. I will be monitoring all the performance of a Cisco network including interfaces status. Is there any way to calculate this data?
Kind regards.
dcruz
6 comments
dcruz
OP3 years agoI ended using a wireshark capture to calculate the number of sessions and pps generated by the collector.
Kind regards.
tswisdom
·3 years agoAs an alternative, you may wish to leverage an HTTP proxy, which allows the Collector to communicate with our servers through a proxy bypass firewall, you may find this to be a simpler approach if this still satisfies your security requirements. If not, we outline the ports and protocols necessary for the Collector on this page.
·3 years agoThe number of sessions should be few, if more than one.
John Mathews
·3 years agoIt is best to get an actual sample from your environment since environments can vary so much. Maybe check the traffic between a current collector which has similar number of devices. You can do a wireshark capture and see the traffic for about an hour and then use that as a basis for calculation. This document may give some clues - https://www.logicmonitor.com/support/collectors/collector-overview/collector-capacity - but will not be specific to your environment. So best to get an actual sample.
dcruz
OP3 years agoIm not since its a new implementation, the FW it’s not installed yet.
John Mathews
·3 years agoAre you able to turn off the FW rule between collector’s ip and datacenter temporarily (for say 1 hour) and then use the firewall logs to see what happened?
