List of Machines under SDT or with Planned SDT
Do we have a dashboard, screen, report which could show all machines having a current SDT or a planned SDT?
A global approach not one-by-one machine...
Dom
Dominique
9 comments
Dominique
OP4 years agoThe first option is excellent thanks for this...
I will check if I need more...
Dom
Dominique
OP4 years agoHello,
Reviewing the access to the Dashboard (Private) / Widget using ... View or manage permissions can only be given to public dashboards. Private dashboards are not available for access through role assignment, but the sharing of a private dashboard can be initiated from the dashboard itself, as discussed in Sharing and Exporting/Importing Dashboards.
Is it possible to share only a widget?
What is the best way to proceed?
Dom
Dominique
OP4 years agoAs I have several access account apparently the GET command is not launched with the correct username... working on this...
Dominique
OP4 years agoAfter forcing the Dashboardid (52) & WidgetId (2227) another error appears... should these two parameters to be added to the properties on the resource as well...
In progress...
Dom
Dominique
OP4 years agoLmaccess.id and lmaccess.key correspond to API credentials. Lmaccount is your portal’s subdomain (The XXX in XXX.logicmonitor.com). Widget_id can be found by managing a dashboard widget, generating a widget embedded URL, and navigating to the end of the URL... Checking how to add it to the Resource.
Dominique
OP4 years agoWhen testing in the Property Source I am getting an error:
Dominique
OP4 years agoHello,
Reviewing this script it is set for A Datasource or a Property Source?
I have create the API access.id & access.key
looking for the dashboard.id & widget.id now... after creating a text widget
Dom
Dominique
OP4 years agoI will try this post
https://community.logicmonitor.com/feature-requests-5/sdt-dashboard-widget-2885 (updated link)
