Issues with Set-LMWebsiteGroup
I'm working with the lm-powershell-module and I'm able to get all my website information and the groups id's but when I try to update the group information so I can bulk move websites nothing seems to happen. I have tried many different ways such as:
Set-LMWebsiteGroup -Name 'CNVPABACUSS252/Servicing/Loan' -ParentGroupName 'Production/Internal/DevOps/Individual Nodes/Abacus Sync'
Set-LMWebsiteGroup -Name $website.name -ParentGroupName 'Production/Internal/DevOps/Individual Nodes/Abacus Sync' -ParentGroupId 77
Set-LMWebsiteGroup -Id 3526 -ParentGroupId 77
I'm sure my syntax is not correct somewhere, but I'm drawing a blank on what it is.
Thanks for your help.
CactusJackFX
3 comments
·2 years agoHmm, that looks somewhat incomplete as it's only showing the GET request and not the PATCH request that it does later. I'm not in a position to test out this module myself. You may need to reach out to the developer of the module.
CactusJackFX
OP2 years agoPS C:\WINDOWS\system32> set-lmwebsitegroup -Verbose -Name 'CNVPABACUSS252/Servicing/Loan' -ParentGroupName 'Production/Internal/DevOps/Individual Nodes/Abacus Sync'
VERBOSE: GET https://caliberhomeloans.logicmonitor.com/santaba/rest/website/groups?filter=name:"CNVPABACUSS252/Servicing/Loan"&size=1000&offset=0&sort=+id with 0-byte payload
VERBOSE: received 74-byte response of content type application/json
PS C:\WINDOWS\system32> set-lmwebsitegroup -debug -Name 'CNVPABACUSS252/Servicing/Loan' -ParentGroupName 'Production/Internal/DevOps/Individual Nodes/Abacus Sync'
DEBUG: Invoked Command: Get-LMWebsiteGroup
DEBUG: Bound Parameters: [Name:CNVPABACUSS252/Servicing/Loan]
DEBUG: Invoked URL: https://caliberhomeloans.logicmonitor.com/santaba/rest/website/groups?filter=name:"CNVPABACUSS252/Servicing/Loan"&size=1000&offset=0&sort=+id
DEBUG: Request Headers: [Authorization:LMv1 2vPfj2uZ6qAM4rnrygFV...] [Content-Type:application/json] [X-Version:3]
That's the debug I got using one of the many ways to try and update the grouping.
·2 years agoI haven't used this module but quick look at the code seems to be able to report some debug info although I'm not sure exactly how to turn it on. Try adding "-debug" to the Set-LMWebsiteGroup command or running "$DebugPreference = 'Continue'" before the line. If you get more details from that let us know what it says.
