ISP network monitoring
Hello, i have a question about monitoring tool for unifi networks, does it also support a way to monitor the ISP connection by means of a ping as in ptrg, i would like to monitor our location on the internet connection if it is down this should be visible, and we use 100% unifi.
ty alex
alexD
1 comment
·1 year agoI don't know unifi networks specifically, but if your border firewall allows external ping on the WAN interface, you can setup an external ping in LM as a way to check for working internet: https://www.logicmonitor.com/support/adding-a-ping-check#PingCheck-CreatingExternalPingChecks
You can also setup the opposite and have your collector ping something(s) on the internet to check if you have internet.
