Is there a way to make an empty escalation chain?
I have some alerts that I dont want to send anywhere, but I also do not want to disable the alerting on instances in the UI or at the folder level either. I have a wide variety of scenarios where alert tuning adjustments and alert disables cant be done. The use cases don't matter.
What I need is a way to have an escalation chain target that is "void" or "do nothing" or some dummy email address (outside our org, since the emails are coming from the LM cloud) that wont actually get the data.
Help?
Lewis_Beard
6 comments
Matt Whitney
Yes you can do that, just create an escalation chain with no stages defined and with the CC field blank. Then use alert rules to define your use cases where you don't want to route the alerts anywhere.
Lewis_Beard
OPLogicmonitor wont let me save an Escalation chain without recipients or escalation chains.
Rob Sapsford
I believe the default escalation chain originally had no recipients. I suspect you changed that as most do.
You can create an escalation chain with no recipients; you must add at least one stage with no recipients.
Note: I tested that you can create an escalation chain this way, but did not test functionality.
Lewis_Beard
OPI could not get that to work. It insisted I put a recipient on the stage 1.
BUT when I tried making a time-based chain, it did let me do that, and it even asked me if I intended to do so. So I do have one now for "Everyday" that is empty.
I guess I can try it.
Thanks
Rob Sapsford
Weird..I was able to create one in both old and new UI.
Lewis_Beard
OPIt must be a "me" thing. I tested it again right before I posted, and I got a red error when trying to add a stage but leaving it blank. But now it works for me too, even for a non-timed one.
I can only assume I did something different previous. So I guess it does work for me. Thanks. :)
