Is Fedora OK for a Collector?
Hello there,
I was curious about installing a collector on Fedora Workstation/Server. I have my own test lab environment in a sandbox and am considering moving my test box over from Ubuntu to Fedora to play around with Cockpit. Does anyone have any experience? I wasn’t sure how strict LM is with distros and how far you could stray from the major supported ones listed. Considering Fedora is upstream for RHEL, I think it could be a good option if you don’t want to give Red Hat their blood money.
Zach_Sterling
6 comments
David_Medina
·3 years agoNo @Stuart Weenig. I should clarify “wasted cycles” haha. It was a lot of fun trying to make it work though!
·3 years agoWait, it works on ARM?
David_Medina
·3 years agoThanks @Stuart Weenig, nice to hear this worked! It’s always fun to test things out (Raspberry Pi’s got a lot of cycles internally at LM!), but I would like to highlight that for monitoring production environments you will want to stick with the supported distros as outlined in our Installing Collectors document.
If problems arise with the collector we may be unable to assist in troubleshooting efforts until a supported OS version is being utilized.
If Cockpit was the driving factor to test with Fedora, it does seem that it is available for other distros we support, so maybe that might be an alternative test case you want to pursue that way you can continue using it on a supported distro if you end up liking it. Thanks!
https://cockpit-project.org/running
Zach_Sterling
OP3 years agoAwesome! I think I’ll give it a try. Thanks a lot for the quick turnaround. 😀
·3 years agoI was able to get it up and running without any issues on a vanilla fedora 37 vm.
·3 years agoJust ran it up in a container using the fedora:latest image. Yum update and yum install which and the installation proceeded for me. However, it failed when trying to call back to LM (i think).
Verified internet connectivity from the internet by pinging 8.8.8.8, but could not ping my portal, but ping may be blocked.
I would say just try it. The collector that runs all collection for k8s used to be based on the python:3.9-slim image, which is debian bullseye. LM has since hidden the collector DockerFile, or at least moved it off github to somewhere i can’t find.
I know it works on rocky, the free version of centos (which used to be the free version of RHEL).
